Lance Armstrong's Drug Testing Results
Ктонить точно понимает что написано?
Lance Armstrong's Drug Testing Results (4/7/2009)
Posted by MOTS | Apr 7, 2009 02: 2 AM PDT | 16 comment(s)
blog post photo
Here is a glossary of terms, which will explain the various elements that anti-doping authorities measure and analyze.
Hemoglobin (g/dL): Hemoglobin is a protein that carries oxygen. It is primarily found in the red blood cells. The concentration of hemoglobin in the body in a non-trained background population is set at 14.2 g/dL. The normal range of such a population is large and includes values above 17 g/dl. In comparison, professional cyclists have an average hemoglobin concentration of 14.8 g/dL (range 12-17.3). A variation in hemoglobin concentration of 7% (range 6-21%) is observed in cyclists. An upper limit is set at 17%g/dl.
Hematocrit (%): Hematocrit is the ratio between the red blood cells and the total blood volume. In males, hematocrit ranges from 40-45% with values above 52% in healthy subjects.
Reticulocytes (%): Reticulocytes are immature red blood cells and the number in % depicts the ratio between the immature and mature red blood cells. The normal range is 0.2-2%. Values below or beyond are considered suspicious. Reticulocytes are highly sensitive for blood manipulations and increase if a blood loss or EPO use is present and decrease with blood transfusions and previous EPO use.
OFF-score: The OFF-score is an equation containing hemoglobin and reticulocytes. By combining the two variables it is possible to determine whether an athlete has used EPO or even performed (autologous) blood transfusions procedures prior to the test. The upper limit set by the UCI is 133.
OFF and Hb z-score: Longitudinal monitoring of athletes' blood profiles help detect blood doping and warrant the exclusion from competition of athletes with aberrant variations in some hematological values. OFF and Hb z-scores are equations that describe the variation in OFF score and hemoglobin in each athlete by including all the measurements conducted on the athlete. If the z-scores are higher than 3.09 or less than -3.09 it indicates blood manipulations.
http://www.livestrong.com/lance-armstro ... g/testing/
blog post photo
- Байк: Giant XtC, Giant TCR
- Реальное имя: Света
- Стиль катания: рваный
Re: Lance Armstrong's Drug Testing Results
Эт расшифровка терминов из таблицы(По типу, что такое гемоглобин и с чем его едят
), которая должна быть выше, где указаны, по видимому, показатели Армстронга.
ну да то что перевести слова то по словарику можно я знаю а вот еще бы их сложить в предложения.. вот где засада то..
- Байк: TG!!
- Реальное имя: Абдурахман
Забавно :)))
А что тут переводить?
Гемоглобин должен быть не более 17%
Гематокрит - неуказано, сказано лишь про общую зону. Ретикулацитов должно быть от 0.2 до 2%, иначе это признаки манипуляций с кровью.
Плюс им этого мало и они ввели два каких=то уравнения (не указывается формула), для первого верхний лимит 133, для второго результат должен попасть в диапазон от -3.09 до 3.09.
Что значат именно эти цифры - ну это просто некие пределы, установленные неким среднепотолочным "я так хочу" методов. (я про то, почему 17, а не 17,3% например). А так - это границы здорового организма. При больших отклонениях это может означать густую кровь, риск тромбоза и прочие радости (которые на результаты впрямую не влияют, но могут повлиять на здоровье, смерть по сне и т.п. - тема очень богатая и рассказывать долго).
В общем все это делается под лозунгом борьбы за здоровье спортсменов. А на деле принимает весьма вычурные формы (например забавные уравнения).
пасиб Андрей
Вовк, а к чему это ваще?
Сайт определяется контентом.
Серег просто интересно мне
А другим?
- Байк: Orbea Alma custom; гибрид 28"
- Реальное имя: VeloMAN
- Стиль катания: рывками
- Способ связи: +79277363047 ICQ: 346-970-949
Мне тоже интерестно 8-)illarien писал(а):А другим?
RIDE it LIKE you STOLE it!
