Новый, размер М, геометрия http://www.specialized.com/us/en/bikes/ ... 9#geometry, договорная
FRAME M5 hydroformed tubing, EVO geometry, tapered headtube, PF30 BB, internal Command Post BlackLite routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, bolt-on cable guides, 120mm travel
SWAT Bottle cage w/ SWAT Technology compatible (not included)
REAR SHOCK Fox Float CTD Evolution, w/ AUTOSAG, air spring, lockout and reb adj., 197x51mm
FORK RockShox Reba RL 29, Solo Air spring, alloy tapered steerer, lockout and reb adj., 15mm thru-axle, 120mm travel
HEADSET 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEM Specialized Trail, 6061 alloy, 4-bolt, 8-degree rise, 6-degree rise, 31.8mm clamp
HANDLEBARS Specialized XC Mini Riser, 6000 butted alloy, 750mm wide, 10mm rise, 8-degree backsweep, 6-degree upsweep, 31.8mm
GRIPS Specialized Sip Grip, light lock-on, half-waffle aramid-infused, S/M: regular, Others: XL thickness
FRONT BRAKE Formula C1, alloy caliper, metallic pad, S/M: 180mm, L/XL: 200mm rotor
REAR BRAKE Formula C1, alloy caliper, metallic pad, S/M: 160mm, L/XL: 180mm rotor
BRAKE LEVERS Formula C1, hydraulic disc, tooled reach adj.
FRONT DERAILLEUR SRAM X7, 10-speed, S3 direct mount for DMD, bottom pull
REAR DERAILLEUR SRAM X9 Type 2, 10-speed, mid cage
SHIFT LEVERS SRAM X7, 10-speed, w/ MatchMaker clamp
CASSETTE SRAM PG-1030, 10-speed, 11-36
CHAINSRAM PC 1031, 10-speed, PowerLink
CRANKSET Custom SRAM S-1250, 10-speed Trail double, PF30 spindle, S: 170mm, Others: 175mm
CHAINRINGS 36/22, w/ alloy guard
BOTTOM BRACKET SRAM PF30, OS press-in bearings, sealed cartridge
PEDALS
RIMS Roval 29, alloy disc, 26mm wide, 32h
FRONT HUB Specialized Hi Lo disc, 15mm thru-axle, sealed cartridge bearings, QR, 32h
REAR HUB Specialized Hi Lo disc, 4x-sealed cartridge bearings, 12mm thru-axle, 142+ spacing, 32h
SPOKESDT Industry Stainless, 3X front/rear 2.0
FRONT TIRE Specialized Butcher Control, 2Bliss Ready, 29x2.3", foldable aramid bead, dual-compound, 60TPI
REAR TIRE Specialized Purgatory Control, 2Bliss Ready, 29x2.3", foldable aramid bead, dual-compound, 60 TPI
INNER TUBES
SADDLE Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST Specialized 2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, Others: 400mm
SEAT BINDER 7050 hard anodized alloy collar, QR, 34.9mm
