Material: Aluminium 6061 Triple butted
Recommended Fork Height /Max: 545mm
Headset Dimension: Tapered 1" 1/8/1.5"
Headset Type: Semi -Integrated ZS44 /ZS56
Maximum Tyre Width (etrto): 60mm
Disc Brake Standard: International Standard
Rear Rotor Max Size: 185mm
Seatpost/Seatclamp Diameter: 31.6mm/34.9mm
Bottom Bracket Type: 68mm BSA
ISCG Mounts/Standard: No
Front Derailleur Type: Top Swing 34.9mm/top pull
Rear Hub Compatibility: 135 x 10mm
Additional Features: Top tube hidden cable path, Tapered headtube
Размер L
2015г
цена ̶1̶4̶9̶0̶0̶р̶ 13000р
Вилка X Fusion Velvet RL2
Weight: approx 3.8lbs/1.7kgs
Spring: Air
Steerer: Tapered
Adjustments: Lockout, Rebound, Air
Stanchion: 32mm, Aluminium
Casting: Magnesium
Axle: LockX 15mm
Axle to Crown: 519mm @ 140mm
Max Rotor Size: 180mm
Additional Features: Can be internally converted to 650b fork using an internal travel spacer.
цена ̶1̶3̶5̶0̶0̶р̶ 11000р
Все в идеальном состоянии, каталось 4 раза по городу.
